How to remove Alde antifreeze drain plug?
I want to drain (and replace) all the antifreeze from the Alde and the first step is to remove the red plug to trigger the gravity drain process. However when I tried to simply remove the red plug it did not budge. It appears there may be some sort of clamp that is holding/keeping the drain plug nice and secure. What's the trick to removing this antifreeze drain plug?
Thanks, Jerry
