Rear mounted bike rack
Has anyone added a rear mounted bike rack on a 400? If so, where? On body of camper? Some sort of extension from the frame? Seems like something might be possible. Need a place to carry
our e-bikes. Can’t lift them up on a Jack-It rack. Bikes won’t fit inside 400. Tow with a 2018 Honda Ridgeline with a tonneau cover.
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,040
    The TaB frames are not designed to support the weight of a rear bike rack.  Most use a rack mounted over the tub or over the hitch.
  • Poche2Poche2 Member Posts: 7
    We had the same issues. We knew the back would not work after talking to NuCamp. We tried a hang on rack on the car but it would hit the trailer when turning. We went with the Jack -it and figured out an easy way to load the bikes. We love it and got the Bump-it that we can use after we get to a site and take bikes on just the car.
    The trick, for us at least, is putting a bungie on the front wheels so they will not flip and turn. Makes it easy for us. I can even do myself. Better with help but can work. Good luck!!
  • ewmjrewmjr Member Posts: 8
    How do these racks affect your tongue weight?
    T@B hopeful - Cincinnati
    Anything you put on the tongue adds to your tongue weight. If you are using an appropriately sized vehicle, non issue. If you’re trying to get aware with a bare minimum or inadequate tow vehicle, forget a bike rack.
