Rear mounted bike rack
gwpurinton
Member Posts: 6
Has anyone added a rear mounted bike rack on a 400? If so, where? On body of camper? Some sort of extension from the frame? Seems like something might be possible. Need a place to carry
our e-bikes. Can’t lift them up on a Jack-It rack. Bikes won’t fit inside 400. Tow with a 2018 Honda Ridgeline with a tonneau cover.
The TaB frames are not designed to support the weight of a rear bike rack. Most use a rack mounted over the tub or over the hitch.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
We had the same issues. We knew the back would not work after talking to NuCamp. We tried a hang on rack on the car but it would hit the trailer when turning. We went with the Jack -it and figured out an easy way to load the bikes. We love it and got the Bump-it that we can use after we get to a site and take bikes on just the car.
The trick, for us at least, is putting a bungie on the front wheels so they will not flip and turn. Makes it easy for us. I can even do myself. Better with help but can work. Good luck!!
How do these racks affect your tongue weight?T@B hopeful - Cincinnati0
Anything you put on the tongue adds to your tongue weight. If you are using an appropriately sized vehicle, non issue. If you’re trying to get aware with a bare minimum or inadequate tow vehicle, forget a bike rack.ewmjr said:How do these racks affect your tongue weight?2019 320s BD Lite, white with blue (“Haven”)
Pacific NW2
