DougH said:.......
Maybe a 4" spring perch or longer stiffer rear coils and longer shocks. But most car platform rear subframes are not made to handle that much weight unless a fabrication shop reenforced the frame.
Doug: I went down that “crooked path” as well; my last car was. ‘79 T/A highly modified to the point it was not street legal. Back halfed, funny car cage (12 point) so that theDougH said:@ChanW True... I should have said subframes in a unibody platform (if that's even the right term). But the horsepower fans often weld and bolt in cross chassis and subframe connectors to stiffen a car up and prevent it from tearing itself apart if you've doubled or tripled the original horsepower. If money is no object you can make anything tow way beyond it's original capacity... no?
P.S. used to have a hopped up Firebird convertible with entirely modified / replaced drivetrain and suspension, with roll cage and various connectors ensuring twist was minimal. The wunnerful hobbies you can have when there's a lot of overtime at work.
I once had a 24' sailboat with a trailer that had an extendable tongue. It was fabricated of 3" square steel tubing about 12 feet long that slid into a 4" receiver. It had a few holes for pins to lock it in place. Needed to allow the trailer to back far enough down the boat ramp to float the boat without submerging the truck. I wouldn't take off on a highway with it extended, but it did markedly reduce the tongue weight.rh5555 said:@Bill_F - Of course! I have a TAB400 with a high tongue weight and no room to add bicycles. A longer frame could be the answer...
What kind of boat did you have? I've seen that arrangement but we just chocked the trailer wheels, disconnected the trailer, then put a pretty strong line between the trailer and the tow vehicle to back down the ramp. But the boat/trailer together only weighed about 1400 lbs.m_lewis said:I once had a 24' sailboat with a trailer that had an extendable tongue. It was fabricated of 3" square steel tubing about 12 feet long that slid into a 4" receiver. It had a few holes for pins to lock it in place. Needed to allow the trailer to back far enough down the boat ramp to float the boat without submerging the truck.
It was an ODay Tempest, 3000 lbs displacement, of which 1250 pounds was the cast iron fixed keel. The trailer was a good 1500 lbs more.Marceline said:What kind of boat did you have? I've seen that arrangement but we just chocked the trailer wheels, disconnected the trailer, then put a pretty strong line between the trailer and the tow vehicle to back down the ramp. But the boat/trailer together only weighed about 1400 lbs.m_lewis said:I once had a 24' sailboat with a trailer that had an extendable tongue. It was fabricated of 3" square steel tubing about 12 feet long that slid into a 4" receiver. It had a few holes for pins to lock it in place. Needed to allow the trailer to back far enough down the boat ramp to float the boat without submerging the truck.
I can see why you would not want to hand steer that down the launch ramp. I had a Wylie Wabbit, which weighs around 900#, with about 400# in the keel. Basically a dinghy on steroids (24').m_lewis said:It was an ODay Tempest, 3000 lbs displacement, of which 1250 pounds was the cast iron fixed keel. The trailer was a good 1500 lbs more.
