Hi all,
New to the forum but looking for real world feedback from Tacoma owners who tow a T@b 400 Boondock. We have a 2020 Tacoma DCSB 6 speed manual and very much like the size and fit and finish of the 400 Boondock. I’ve read a bunch of posts on here and elsewhere but there’s conflicting feedback on the Tacoma’s towing ability with these trailers. We’re in Alberta so will be spending a lot of time towing in the mountains and we’re already at 3500 ft above sea level. Looking for any advice on towing setups and what kind of mpg folk typically get. Thanks in advance!
                0 ·
While all of Toyota’s specs said the Tacoma can tow up to 6500 lbs with 650 tongue weight, I would not do it again. I truly believe the difference in height between the Tacoma and the 400 is too great and the 400 is just like a wind block behind the Tacoma.
Odessa, Fl.
I've always had the understanding that an auto transmission is less efficient than a manual, power lost in the fluid, and can overheat if not properly sized for the load.
No?
2020 Toyota Tacoma TRD 4x4
Non-towing mileage with premium gas is about 26 mpg with it. While towing we get 15 in the lowlands and 13 in the hills.
If I were taking on the whole country in a months-long trip I would probably get something bigger. But for our style the Tacoma is great, and it's economical and useful when not trailering, which is most of the time.
Isn't an automatic transmission bound to give poorer fuel mileage?
A quick Google suggests that generally the manual tranny is more fuel efficient, but that the variety of gears that an automatic can provide allow it to be programmed to shift to the most efficient gear ratio.
But, it seems that the more shifting, the more power is wasted in between gears, being left as heat in the hydraulic fluid.
I've always had a preference toward manual tranny for the reasons I said. It would figure that I've had it all wrong all these years.
When I decided to upgrade to a mid size truck, larger than the Nissan, I wanted a good tow vehicle, and all my research showed the auto tinny had a much higher tow rating, looking at the Colorado and Dodge Dakota. I went with the Dakota and it’s max tow package (5500 lbs) was tied to an auto tranny. This was a four speed and worked well.
I was wondering why a Ford F150 with the same engine size as the Tacoma is able to tow a T@B 400 much better? I know towing capacity is not all about horsepower but when it comes to towing up steep mountain passes isn't that what makes the difference between cruising up at 55 versus 40mph?
Just asking?
SW Colorado
2020 F150 3.5 ecoboost
Columbus, OH
My next Tacoma I’ll be going back to Airlifts. I like the stock ride unloaded.
Odessa, Fl.
Tacoma is acceptable for short distance weekend tow/camping trips.
Because the tank is relatively small you will need to start looking for gas between 180 and 220 miles If you live in an area with few gas stations you will have range anxiety.
If your planning long trips like me, you should consider another tow vehicle.
When I purchased my 400 and the Tacoma, I thought I had the perfect rig but I was wrong.
In December 2020, I sold my Tacoma and purchased a RAM 1500 Diesel with 4 WD, air suspension and 33 gallon tank. I considered a Tundra but decided against it because the low posted MPG and high CO2 emissions. The RAM has much lower CO2 emissions and when not towing the MPG is rated at 29 highway. I haven't towed my 400 yet, but hopefully I will get much better MPG and won’t need to fill up the tank every 200 miles.
A Taco towing a 400 in the mountains is getting a workout but arguably it is one that it should be able to sustain. The pre-2016 motors may be better suited. The Atkinson engines have not been well received.
I'm towing a 320 with a 4 door 8 cylinder RAM, and I can feel it behind me, especially hitting holes/ruts and railroad crossings.
We just went to Disney from Tampa on I-4 (which has to be one of the worst roads for idiot drivers in the US) and traveling between 55 to 60 I got about 15.6 MPG. Normally that trip without the T@B I can get 22 to 24 MPG staying around 58.
On the way home @ 56 MPH I got up to 18.3 MPG. Guess Tampa is downhill from Disney! When I pushed the speed up to 60 the MPG started dropping and it went down to about 17.1
To each his/her own, but I wouldn't want to tow a 320 and especially a 400 with anything less than a full sized truck, van or Suburban type SUV.
Why take the risk of not being able to stop, accelerate if needed, and keep from killing an expensive TV.
Tampa FL
