Hi.  We are only getting very short (maybe 5 seconds) of hot water before it goes cold again.  After reviewing some discussions and one of the Nucamp videos I checked the mixing valve but it is already in the max position.  Any guidance would be hugely appreciated!
                0 ·
__ Look under the rear bunk, driver’s side and make sure the yellow pressure relief valve handle is horizontal, not pointing up.
__ Check Alde contro, panel for glycol temp, to make sure it has heated up.
https://tab-rv.vanillacommunity.com/discussion/comment/117335#Comment_117335
Also, on the Alde control panel, there is a "shower" boost mode...which also helps create a stready stream of hot water. Look up how to set this if you don't already know - it works with the Alde flow to allow virtually unlimited hot water for a 30 minute period...when you need it.
