Noise level on Unibody vs Body-on-Frame
vijay
vijay Member Posts: 3
I just bought my first RV camper - the Tab400 and am a total newbie. During my research, I heard that unibody SUVs transmit the clanking from the hitch making for a noisy ride, while body-on-frame SUVs isolate those vibrations resulting in less clanking inside the cabin.
Do any of you have experience with both a unibody (most modern SUVs?) and a body-on-frame (some of the Toyotas and a few other SUVs) with your Tab400? Was the difference enough to push you one way or the other.
Considering we might spend many hours a day in the cabin, I'd like those long drive days to be as relaxed as possible, which is pushing me towards the Toyota 4Runner, but perhaps I am overthinking this?
Thanks!
    Get a hitch tightener and call it a day.
    pthomas745 Administrator, Moderator Posts: 4,662
    Something like this.  Your "ball mount" goes into the vehicle's "receiver tube".  There is a tiny bit of space between the mount and the tube.  When you attach a trailer to it, that little space can cause a bit of noise.
    This makes that noise go away.  Still the occasional noise, but 90 percent gone.
  • atlasb
    atlasb Member Posts: 584
    due to the tongue weight of the 400, have never had hitch rattle.  Did with our 320 though.
  • Denny16
    Denny16 Member Posts: 5,430
    No, but you can still feel the slack being taken up between braking and acceleration of the TV.  You feel this even with a pickup truck.
  • Marceline
    Marceline Member Posts: 1,770
    I have a unibody SUV. Yes, I had some clanking due to a loose-ish fit between the ball mount I'm using for the T@B (I have another ball mount that has less rattle) and the receiver. I solved it with a hitch tightener. Some people ignore it but I associate the sound with metal fatigue so I wanted to stop it. I've never heard of this being specific to unibody vehicles, and frankly that doesn't make much sense to me.
