Victron 75/10
I have a 320 CSS using a group 24 lead-acid battery. I want to upgrade to a AGM. Will this controller work with the AGM? The manual says nothing about battery types.
52 nights
    pthomas745 Administrator, Moderator Posts: 4,694
    Yes.
  • Denny16
    Denny16 Member Posts: 5,430
    The solar controller is sized for the solar panel, and can be adjusted formthe battery.  That said, the larger the battery, then.inter it will take to charge it, if it gets a heavy load on it.
