Victron 75/10
Kentsb
Member Posts: 67
I have a 320 CSS using a group 24 lead-acid battery. I want to upgrade to a AGM. Will this controller work with the AGM? The manual says nothing about battery types.
52 nights
The solar controller is sized for the solar panel, and can be adjusted formthe battery. That said, the larger the battery, then.inter it will take to charge it, if it gets a heavy load on it.
cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
