Small Keder accessory
Can someone tell me the spec on the inside diameter of the keder rail on 320S BD? I am considering getting these "light holders" but unsure if the size is right
https://smile.amazon.com/gp/product/B0006IX7W4/ref=ox_sc_saved_title_6?smid=ATVPDKIKX0DER&th=1
2021 TAB 320S  Boondock
  • There are some dimensions list here
  • Denny16
    Denny16 Posts: 5,430
    Looks like it has two different size inserts for the rail system.  Worth giving it a go and see.
  • An alternative:
    I've been successfully using a nylon cable tie for this purpose.  I make a loop with the cable tie, cut the tail end off and insert the "head" of the cable tie into the keder channel.  This works well for light loads.
    2020 T@B 400 Boondock Lite.
    2020 Chevrolet Colorado ZR2
    with the 2.8 litre 4-cylinder Duramax diesel.
    ScottG Posts: 5,688
    edited February 2021
    Here are my measurements from a screen skirt project on my 2015:
    8.5mm (or 5/16") keder cord works well--it has a flap which gets sewn onto whatever it is you are trying to attach to the rail.
    The gap is the rail is 1/4". The width of the opening (where you slide the cord in) and the inside channel is 3/8" - 7/16" at best--it's hard to get the calipers in there for an exact measurement.
  • we used the same size as ScottyG on our 2016 320.
    Tampa FL
  • Thanks all for the input. Will give them a try
