Small Keder accessory
jcrystal
Member Posts: 32
Can someone tell me the spec on the inside diameter of the keder rail on 320S BD? I am considering getting these "light holders" but unsure if the size is right
https://smile.amazon.com/gp/product/B0006IX7W4/ref=ox_sc_saved_title_6?smid=ATVPDKIKX0DER&th=1
2021 TAB 320S Boondock
There are some dimensions list hereMike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ
Looks like it has two different size inserts for the rail system. Worth giving it a go and see.
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast. -
An alternative:
I've been successfully using a nylon cable tie for this purpose. I make a loop with the cable tie, cut the tail end off and insert the "head" of the cable tie into the keder channel. This works well for light loads. -
Here are my measurements from a screen skirt project on my 2015:8.5mm (or 5/16") keder cord works well--it has a flap which gets sewn onto whatever it is you are trying to attach to the rail.The gap is the rail is 1/4". The width of the opening (where you slide the cord in) and the inside channel is 3/8" - 7/16" at best--it's hard to get the calipers in there for an exact measurement.2015 T@B Max S (320)
we used the same size as ScottyG on our 2016 320.2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL -
Thanks all for the input. Will give them a try2021 TAB 320S Boondock
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
