Diy 2 gal garden sprayer shower for RV travels
gbell
Member Posts: 88
Photo too large and deleted. Moderator
I found how to make the below "shower" on youtube, very easy to make with 3parts from home depot, it really works as an extra shower, to wash the tab, spray anything. 2 gal sprayer container gives a nice shower. We'll be non electric camping this summer and I plan to use this help limit our battery usage.0
That is a really nice one. Did you make one? Send us the youtube linky. Verna has suggested this method for years. I have the sprayer she suggested: smaller, but still extremely useful.
Towed by 2014 Touareg TDi1 -
youtu.be/rp3rv5og0fk
This was from adventurevanman youtube site, he did a good job showing the parts and how to. It works very well. There are a lot of other youtube sites that have made this but I think his was the easiest to follow. I added an aquarium thermometer to the container to see the temperature.1 -
If you painted/covered it in black and left it in the sun, do you think it would heat up the water?gbell said:youtu.be/rp3rv5og0fk
This was from adventurevanman youtube site, he did a good job showing the parts and how to. It works very well. There are a lot of other youtube sites that have made this but I think his was the easiest to follow. I added an aquarium thermometer to the container to see the temperature.2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL0 -
...in theory...trick would be getting the paint to stick. scuff the surface then clean thoroughly before painting...Tampakayaker said:
This was from adventurevanman youtube site, he did a good job showing the parts and how to. It works very well. There are a lot of other youtube sites that have made this but I think his was the easiest to follow. I added an aquarium thermometer to the container to see the temperature.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback0 -
Some sites told of painting it, but I will just put cold water in first then hot to proper temp. The 2 gal container is pretty thick might be hard to get solar heat into it. What's nice about this is the length of tubing from the container plus the kitchen sprayer tubing makes it 7.5 feet long. Plenty of length to work with.0
Tampa FL1 -
Or just wrap it in black tape like gaffer tape.
I was thinking black neoprene or some similar dense black foam glued or taped on.jkjenn said:Or just wrap it in black tape like gaffer tape.2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL0 -
A little fancier and a lot more $$$$$
https://www.shop.spunaluminumgastanks.com/Pressurized-Solar-Shower-Tubes_c171.htm?fbclid=IwAR2FrTTeKi8rUtswrBJ7ttmbRxxw94wFKgLBj_PyOLuXQkuUtlJ5x_1ketk_aem_ASZt3o4GS80MuuQmf4kdMpNlpCHh2WdvL_oWo_eDDqmY8CWWN0DZn-j0hDmOkOpXE4BjoK6PxYubuuQxQByVS0ESeduy6ht4m5bxYICkHkpCKF0Jf5pQLgAziImtB62hyoM
Tampa FL0 -
We we had one on our sailboat for years. I painted ours with plastic bumper paint from Ace Hardware.2022 TAB 400 Boondock, 2019 Toyota Tacoma Sport 4x4
Odessa, Fl.
- 956 Air Conditioning & Refrigeration
- 921 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
