Diy 2 gal garden sprayer shower for RV travels
gbell
gbell Member Posts: 88
edited February 2021 in Products and Accessories
Photo too large and deleted.  Moderator
  • gbell
    I found how to make the below "shower" on youtube, very easy to make with 3parts from home depot, it really works as an extra shower, to wash the tab, spray anything. 2 gal sprayer container gives a nice shower. We'll be non electric camping this summer and I plan to use this help limit our battery usage.
  • gbell
    pthomas745 Administrator, Moderator Posts: 4,699
    That is a really nice one. Did you make one?  Send us the youtube linky.  Verna has suggested this method for years.  I have the sprayer she suggested: smaller, but still extremely useful.
  • gbell
    youtu.be/rp3rv5og0fk
    This was from adventurevanman youtube site, he did a good job showing the parts and how to.   It works very well. There are a lot of other youtube sites that have made this but I think his was the easiest to follow.  I added an aquarium thermometer to the container to see the temperature.
  • Tampakayaker
    If you painted/covered it in black and left it in the sun, do you think it would heat up the water?
    Tampa FL
  • 4ncar
    4ncar Member Posts: 1,072
    ...in theory...trick would be getting the paint to stick.  scuff the surface then clean thoroughly before painting...
    2018 320S Outback
  • gbell
    Some sites told of painting it, but I will  just put cold water in first then hot to proper temp.  The 2 gal container is pretty thick might be hard to get solar heat into it.  What's nice about this is the length of tubing from the container plus the kitchen sprayer tubing makes it 7.5 feet long. Plenty of length to work with.
  • Tampakayaker
    They do make spray paint for plastic.
    Tampa FL
  • jkjenn
    jkjenn Member Posts: 6,425
    Or just wrap it in black tape like gaffer tape.
  • 4ncar
    problem solved
    2018 320S Outback
  • Tampakayaker
    I was thinking black neoprene or some similar dense black foam glued or taped on.
    Tampa FL
  • GatorEgg
    GatorEgg Member Posts: 482
    We we had one on our sailboat for years.  I painted ours with plastic bumper paint from Ace Hardware.
    Odessa, Fl.
