jkjenn
Member Posts: 6,417
Sterling, VA
A flag should fly without obstruction(s). I have a 24" piece of rebar which I hammer 12" into the ground. I made a flagpole of PVC pipe. I drilled holes into the PVC (top section) and attached the flag with zip ties.
Note: I sectioned the PVC in half and, when I need to fly the flag, I simply screw (Don't muscle) the two halves together. I slide the bottom of the PVC over the rebar. I've never had a flag blow over, even in stiff winds. The flagpoles have never snapped!! Amazing!
I have made dozen of these for my organization, which attends many Military & Veteran events. They work great. I've not ever had a problem!
The flag flies properly. Storage is very easy. Simply unscrew the PVC halves and roll inside the flag for easy/proper storage. If anyone wants photos, go to YouTube, or Google: Patriot Guard Riders. Good Luck. Thanks for showing your Patriotism by flying the FLAG!
I carry dozens of the above noted in the back of my SUV without problem.
About the only time I'm within range (boosted or not) of open-access wifi is if I'm parked outside a library :-)
Yes, I did get the Weboost 4GS (previously Wilson Electronics) booster. I have not had a good chance to really try it out, but should this weekend. My brother gets very weak service at his house. I believe I could mount the antenna on it, too. I think it would be fairly simple to mount a metal plate or bracket of some kind. Some new wireless boosters will probably come out next year, but it sounds like the cost will be a lot higher, so it might be a good time to buy in. I am not sure they really expect huge gains in reception from newer products, either.
I will do a full write-up once I get everything up and running. The antenna I got is indoor/outdoor so it could be used without deploying the flag pole, which could come in handy in bad weather or overnight at Walmart. I got a Ubiquity Nanostation M2. I plan to mount it on a 14' Flagpole to Go and mount it with a rod holder, similar to Dale's.
The Nanostation was open box from Amazon Warehouse so I paid half the price. We will see if it works. Amazon Warehouse isn't what it used to be, I have recently found out. Also, the M2 requires ac power. It uses POE front the antenna to an adapter and then ac power. The outside outlets will be perfect when I have power and I can use one of my Goal Zero devices when I don't. I have not found a simple way to runt he POE over 12v yet and not sure it is worth the effort because I would guess if you can access WiFi, you probably have electricity. This might be really nice for state parks that are starting to offer WiFi. I know that OH and CO both have some parks that offer WiFi.
The M2 will actually come in handy in my own backyard as my home WiFi is pretty weak into he backyard. I have a USB antenna, but it is finicky. It did help at campgrounds last summer, though.
The biggest problem I have is that the USB CPE USB cord tends to get loose and so the connection is constantly getting dropped.
The Nanostation packs a bigger punch than a standard item like an airport express or normal extender, from what I understand Al; lowing you to connect over longer distances. It is meant for indoor/outdoor use, so that is also a bonus. I have read, however, that it is not for the computer challenged. There are a pretty good tutorials out there and I am fairly network literate, albeit a little rusty. It does require a router for more than one device to connect, but I can use my My Passport Wireless for that.
