Step modification
DawnS
Member Posts: 4
Is there a 2 step replacement available somewhere that also folds in under the T@b, and turns on the light when folded out? I have a 2021 T@b 320s boondock.
Dawn
Dawn
Not that I know, but you can purchase a short portable step to place in front of the attached step.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Vernas link is elegant.
I made a couple of 2x4 and plywood boxes for extra steps when we had our pop up.
I've seen pictures of people using plastic spa steps instead of the fold out step.
Only problem is they are bulky to store/transport.2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL -
Even with a pickup truck, space is valuable. These legs fold and the legs are adjustable. I fold it up and lay it inside the T@B door (wiping it off as necessary). Easy to use, lightweight.Verna, Columbus, IN
You mean your truck bed doesn't have the Tardis option with infinite space? You got gypped!Verna said:Even with a pickup truck, space is valuable. These legs fold and the legs are adjustable. I fold it up and lay it inside the T@B door (wiping it off as necessary). Easy to use, lightweight.2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL -
Looks perfect, thanks Verna.
I have stepped on @Verna's step and it is really solid.
Thanks $60 sounds much better than the $200 to reboot my old step.Furbug 2014 T@B S - TV Toyota RAV
My Outback sits slightly higher than the standard T@B. The Harbor Freight step stool for $20 bucks is exactly at the factory pull-out step height. Been using it for several years. The factory step is "squishy." I don't feel comfortable using it.2016 Outback 320
The steps are also useful if you have a side tent. The tent skirting hides the pull out step, so the portable step comes in handy.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
I cut a slit in the skirt to let the step out and down.Sharon_is_SAM said:The steps are also useful if you have a side tent. The tent skirting hides the pull out step, so the portable step comes in handy.After several near falls, we also found the step too squishy and too small, so I built a two-step stacking porch out of PVC boards, some dowel pins, and a couple of latches to hold the pair together.
At most campsites, we use both, but at those that are sloped where the door side is lower, we just use the one step.
I also taped the slit closed, wish I hadn't cut it.
2019 T@B 400 Boondock Lite, BMW X3 -
Looks like your top step is just below the T@B floor, and the bottom step is about the height of the slide out step?m_lewis said:
What's the approximate weight?2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL -
I totally agree with the to small and squishy. Our solution would not solve the height problem but has worked very well for the other two. I enlarged the step with a piece of 3/4” plywood. Bolted directly to the original step. I then mounted a small scissors jack from Harbor Freight to the underside. When the step is retracted there is still a portion extended. This works well for quick stops. Where we do not want to fully extend the step. When the jack is retracted it no lower than the lowest part of the step assembly. This has served us well for the last 5years. - Hash T@B Fun
another @Dalehelman first!!!TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback -
Dale - what is that strut you have on the door????2016 Outback 320
@Tabaz It allows us to close the door without having to go outside to release the latch. It’s also handy on very windy days, but you don’t have the wind issue down where you live.Photo resized.
- Hash T@B Fun
Clever as usual Dale. Would not work for me because I have a thin metal rod that I attach to the door's plastic latch and the receiver on the sidewall. This allows me to lock the door in an open position without the top of the door hitting the XL Visor. I think that too was one of your mods.2016 Outback 320
@Tabaz Correct, but the strut is mounted so the door is not in the full open position. So it doesn’t interfere with our visor. I also took a piece of 1/4” clear tubing about a foot long. Slit on side with a razor knife. Then I slipped it over the top edge of the door so the aluminum doesn’t rub the underside of the visor.
- Hash T@B Fun
I picked up something similar to Verna's, as I'm finding it is needed with our Boondock..our legs aren't adjustable but love how compact it is..I do wish NuCamp had a switch inside to turn the step light out after you hit the sack. Canadian Tire again filled our needs.Former 2017 T@G Max XL
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada -
Dale needs to publish a book!!! lolTV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback -
@Dalehelman. How did you attach the rug to the step? Is it just laying on it or secured? I just don’t love the kind you have to wrap around and strap down.2021 T@B Boondock 320S | 2021 Toyota Tacoma SR5 V6
@GeorgiaMB
Glue and flat head screws.- Hash T@B Fun
- 916 Introductions
- 72 Teardrop Groups & Links
