Gray water only sewer hose recommendation--320S
Oyaji
Member Posts: 31
Anybody have a recommendation for a gray water only sewer hose (with necessary connections) for a 320S? (It has a cassette toilet)
I'm almost embarrassed to be asking such a trivial question, but there are so many options for sewer hoses in the market place, and at different price points , I'm stumped. And my trailer didn't come with the apparently standard freebie hose.
I only want to buy this thing once! Thanks.
I use two of these (one for extended reach if necessary). No issues to date. If you're in climates that have extremes keep that in mind as high solar exposure and/or cold tempuratures can shorten the lifespan. Fortunately if it does leak, it's only grey water. No good, but so much better than the alternative!2020 T@B 400 "OTTO" (build date 08/19)
San Diego, CA
www.airbossone.com
https://fineartamerica.com/profiles/owen-ashurst/shop1 -
@Oyaji, we use the rhino hose. Ours is for black and gray. We've had 4 people in a 320 S for 2 months at a time and emptying the tanks was a priority. We've used the rhino hose at 0°F and at 125°F and every temp in between. No leaks, no failures, no problems. I highly recommend it. Btw, it is the first and only gray/black hose we have ever had, as our dealer gave us absolutely nothing as part of our trailer purchase.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus.1 -
I would use the Sewer Solution as it is a much smaller diameter hose. As You will only be dumping your gray water tank. I have used it for both black and gray water with great success. Look up Sewer Solution. Art2019 TaB 320 S Boondock Edge1
Don’t feel bad!! I was sitting here wondering the exact same thing as we are picking up our 320 next week! Thanks for asking the question!!!2021 T@B Boondock 320S | 2021 Toyota Tacoma SR5 V60
I would get on of these and a 10’ or 15’ of 3/4” garden hose. It won’t drain as fast as a 3”. Probably less than 5 minutes. Once in a while you could fill the tank with fresh water and drain it in your yard to get a good flushing action.
Valterra T1020-1 Waste Valve Cap - 3" with Capped 3/4" GHT, Black
by Amazon.com
Learn more: https://smile.amazon.com/dp/B0006N5RYK/ref=cm_sw_em_r_mt_imm_awdb_36AXN7D67K7ET45MSB8V- Hash T@B Fun
2 -
+1 for the Rhino-Flex, but be sure you check that the ends are screwed into the hose securely when you use it. I believe it was @Michigan_Mike that was lucky enough to experience the disincorporation if his Rhino while in use... Couldn't have been pretty!
The Sewer Solution I found to use a whole lot of water for its ability to 'macerate', took a lot of time (for solids), and then I was left with more parts to clean. I finally got rid of it.
The smaller diameter hose is easier to stow and clean. Just a little more time at the dump-site. You can timee your dumping at the dump station so there is no-one waiting in line behind you (easy with off-season camping).
If you're just doing gray water, with no solids, and you want a small diameter hose, I'd go with the waste cap that @Dalehelman referred to.Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya2 -
@Oyaji - be aware that the small, Valterra cap outlet makes for a very slow emptying of your gray water. That is fine if you are dumping into a portable tank at your campsite, but you may have a long line behind you at a dump station. We have the Valterra cap used at a campsite and a Rhino Flex used at a dump station.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Wow, I'm liking that Valterra cap idea, at least to start. As we all know, there isn't a whole lot of storage space on or in a 320S!
