I know there have been several discussions on this topic. I've been perusing them, but as most popular subjects go, there is a wide scattering of opinions and options, so I'm kicking my specific questions out here.
When I removed my air conditioner I disconnected its outlet as it served no purpose. I'm now planning to reconnect it and use it to charge phones up on the valance when I have shore power. (The other two indoor outlets are not in convenient locations.)
This got me thinking that I might add a 12V outlet in the same location to use when I do not have shore power. Based on past discussions, my current thinking is to install a generic 12V "cigarette lighter" outlet and use it with a generic plug-in USB charger (same as I do in my vehicle). I would then run a dedicated wire back down to the converter area and splice it into the 12V circuit serving the existing outlet over the sink (and maybe also the lights--I haven't checked in a while).
So, are there better options than a generic 12V socket and plug-in charger? (USB outlets seem to get panned for their low amperage, phantom drain, and apparent lack of durability.)
Is there a better place to wire this in than the existing circuit I mentioned? (I would wire it in to the circuit for the former A/C vet fan, but that is switched and currently in use for something else.)
Thanks for any additional insights or advice.
1 ·
Both for components and wiring.
Amazon.com: Kohree 12V Marine Car Charger Socket Panel, 4 in 1 Waterproof Boat Cell Phone Rocker Switch Panel with 12 Volt Dual USB Power Outlet Cigarette Lighter Socket for RV Marine Boat Camper Truck Automotive: Home Audio & Theater
I used one to build a portable power supply. It has both USB and 12V lighter, it is switched (no parasitic drain when off), and has a meter to know basic state of charge for your battery.
2019 320 Boondock Edge - Sold Jan 2022
I think the back outlets were added the next year, largely in response to customer demand.
https://www.amazon.com/OIIKI-Connectors-Connector-Solderless-Electrical/dp/B08GPZ2F4V/ref=pd_lpo_328_img_1/139-9599493-0857349?_encoding=UTF8&pd_rd_i=B08GPZ2F4V&pd_rd_r=f3ca983f-f606-4d98-819e-ec0b81f2108c&pd_rd_w=n0SaT&pd_rd_wg=u4Nk6&pf_rd_p=2eae1586-a44a-4b21-997a-1dfc1740e496&pf_rd_r=2SVHKAJCDEDMQCP6SGPG&psc=1&refRID=2SVHKAJCDEDMQCP6SGPG
Half-taps should work fine (nuCamp uses them all through the trailer) but I prefer properly crimped connections. I purchased a ratcheting crimper tool a few years ago and have never regretted it.
T@BMahal
'04 #100
Do you have any spare slots?
PS I hate the Scotchlok connectors our trailers seem to be built from. As a former auto tech, I spent searching for bad connections which usually originated at one of these.
Jeff & Amy
I also used one of the panels to make a portable power station.
I'm with you @JeffroNC on those Scotchlok connectors, when I was auto mechanizing my way through college those were the bane of my existence, plus they're just UGLY.
Is that a false bottom installed over the floor of the compartment?
2020 T@B 400 BD Lite
I would recommend the 12V plug under the bench as it would look neater with no wiring showing.
The box is a .30 Caliber size (plastic) from Harbor Freight.
0.30 Caliber Ammo Box (harborfreight.com)
The power comes from two 8Amp 12V batteries, wired in parallel.
Cabela's Rechargeable 12V Battery | Cabela's (cabelas.com)
Theoretical power is about 190 Watts. Output is comparable to the smaller size Yeti Goal Zero, albeit without some of the Yeti components (or cost). It was something I made for emergency recharging here in 'hurricane country'. I've made several for family and friends too.
My T@B, the Boondock Edge model, had an additional Blue Sea panel in the electrical compartment with three open slots. Lucky for me, I didn't have to do as much work as you.
Here's a wider view. I rebuilt the bench box and added a 3/4" plywood panel on the outside wall cut out for the wheel well so I could mount things to it and have a stronger support for the back edge of the bench seat. We sleep on the twin bed idea so my seat top is made to slide out 3.5" so we have a slightly wider bed over it. The cross support connected to the new outer plywood (notched for the GFCI) is wide enough to catch the seat plywood so it is fully supported when pulled out.
This pic is before I changed the base cabs to cherry veneer plywood.
The small blue box is just a junction box (now has a cover) because the 120v line was not long enough to lay neatly under the false floor so I had to lengthen it. The Alde plug is still in the Alde closet.
