 SgtYork
                    Member Posts: 34
SgtYork
                    Member Posts: 34
            We took the 2021 TAB 400 out for the first time Tuesday and noticed
the side window was messing up the black decal and making marks on the
sidewall. Attached is the picture I took of it. Looks like latch is adjusted
all the way out.
Also, my 2019 400 has clear plastic decals at the corners of the front and rear windows to prevent such damage. Due to the pressure of the window corners on the decals they moved and became deformed. nuCamp service replaced the decals for me and within 9 months the decals were again deformed and moving.
Southern California
Full-timer since 2019
By opening the window all the way, it will allow you to slide it to the left and right for a slight adjustment. I would try this and see if it will help. We can also provide clear corner decals to help with the rubbing. These will get installed on the sidewall beneath each corner of the window. You can do this yourself or have a dealer of ours perform the repair. We have a dealer located in Nashville
I'm going to try the side to side fix first.
