I'm installing two Renogy 100W flexible panels on our 2019 T@b400 with full closet. I want to penetrate the roof next to the vent and run the wires down along the vent, which I believe was the original factory installation before they went with a more stealth wiring installation. I'm trying to find a picture of the roof where this wire penetration is made, but haven't found one in all the solar threads I've searched through. Does anyone have a good picture or good information on where to drill the hole in the roof for the wires? I don't want to hit any of the roof frames.
Thanks in advance!
Rich
2019 T@b 400
Bellingham WA
0 ·
2013 Tundra TRD 5.7L
Massachusetts
https://www.amazon.com/Blue-Sea-Systems-CableClam-0-68-Inch/dp/B0002UEOIW
WilliamA
2017 T@G XL
WilliamA
2017 T@G XL
Yes, I routed the solar cables through the sidewall of the vent cover, caulked liberally and then routed the cables down the side of the vent pipe just as you will with the more permanent dual wire gland. The hardest part for me was trying to figure out the cable path to the battery. The attached pictures may be helpful to you:
1. The best picture I could find on the Forum showing the vent pipes behind the bathroom sink (thanks to @jimcenname)
2. Cables coming down vent pipe chase behind the bathroom sink and exiting bathroom through hole drillled near red pex pipe
3. Cable entering area under frig/big drawer (wardrobe)
4. Connection to solar controller (tacked on sidewall of Alde area) and exiting to battery under bed.
Your setup with the wardrobe may be slightly different but hope that helps. Have fun!
