Kitchen Pegboard
We're not normally Ikea shoppers, but our son asked us to pick something up. While there we spotted this slotted pegboard and thought it might work in our T@B on the wall next to the stove. Now we have to go back for more of the accessories.  ;)
  • Homebodyatheart
    Looks good. How exactly did you attach it to the Azdel?
  • AnOldUR
    AnOldUR Member Posts: 1,759
    edited March 2021
    @Homebodyatheart ... Thanks. I didn't attach to the Azdel. If you look close at the picture, you'll see some of the 3/4" square pine that the peg board is screwed to. The bottom standoff is screwed into the countertop. The top is screwed into the bottom of the cabinet. I did not trust the Azdel to hold the weight.
  • Verna
    Verna Member Posts: 6,876
    @AnOldUR, did you fabricate the holders going around the cups, spices and pots?
  • AnOldUR
    @Verna ... They also came from Ikea. They had a lot of accessories that go with the board.
  • Verna
    Thank you, @AnOldUR.
  • Homebodyatheart
    @AnOldUR smart! Azdel isn’t something you want to drill into or through unless you want new ventilation (a hole...) or you know what’s there. These are samples I got from NuCamp. I like the clean look of your setup!
  • Tink
    Tink Member Posts: 28
    Brilliant!
  • ontheroad
    ontheroad Member Posts: 489
    Looks fantastic!
    Former 2017 T@G Max XL
    2021 T@B Boondock CS-S
    2018 Nissan Pathfinder
    Ontario, Canada
  • Tink
    @AnOldUR what size skadis pegboard did you buy? Was it easy to cut to the shape needed? Thanks.
    I love the idea of the pegboard because I can change things up easily 😊
  • AnOldUR
    @Tink ... I believe it was a two foot square piece. It cut easily with our band saw. I made a cardboard template first. Once I got that to fit to my satisfaction I went to the pegboard. It still took a little tweaking. If you look close you'll notice that the saw cut at the top is not inline with the pegboard holes. The countertop and the cabinet were not parallel. That might just be my trailer?
  • Tink
    @AnOldUR thank you!
