Kitchen Pegboard
AnOldUR
Member Posts: 1,762
We're not normally Ikea shoppers, but our son asked us to pick something up. While there we spotted this slotted pegboard and thought it might work in our T@B on the wall next to the stove. Now we have to go back for more of the accessories.
8
Looks good. How exactly did you attach it to the Azdel?2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0
@Homebodyatheart ... Thanks. I didn't attach to the Azdel. If you look close at the picture, you'll see some of the 3/4" square pine that the peg board is screwed to. The bottom standoff is screwed into the countertop. The top is screwed into the bottom of the cabinet. I did not trust the Azdel to hold the weight.
@AnOldUR smart! Azdel isn’t something you want to drill into or through unless you want new ventilation (a hole...) or you know what’s there. These are samples I got from NuCamp. I like the clean look of your setup!
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1 -
Brilliant!1
Looks fantastic!Former 2017 T@G Max XL
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada1 -
@Tink ... I believe it was a two foot square piece. It cut easily with our band saw. I made a cardboard template first. Once I got that to fit to my satisfaction I went to the pegboard. It still took a little tweaking. If you look close you'll notice that the saw cut at the top is not inline with the pegboard holes. The countertop and the cabinet were not parallel. That might just be my trailer?
60,865 camping miles through the end of 20250
