Sudsy hot water after dewinterizing
PJE
PJE Member Posts: 4
We have just finished dewinterizing our 2018 320S and while the cold water runs clear the hot water is sudsy. Any ideas on why that is? What have we done wrong?
    edited March 2021
    Sounds like maybe the antifreeze was not completely rinsed.  Was the Alde bypassed until after the rinsing?  The Alde may have some residual antifreeze in it.
  • PJE
    PJE Member Posts: 4
    This is our first time doing this so possibly not! Will go back and try to figure that out. Thanks.
  • PJE
    PJE Member Posts: 4
    That May have been the problem but now I’m confused about when to lift the yellow relief valve lever and when to leave it down.
    Well, if the Alde tank is now filling and heating, just turn off the Alde at the display and hook up to city water and keep rinsing and emptying the Alde tank until no more suds.
  • PJE
    PJE Member Posts: 4
    Thank you! Clear water - hot and cold. Slowly but surely we are going to figure this all out.
    You’ll get there!  I sometimes think we learn more by stumbling a little along the way :)
    pthomas745 Administrator, Moderator Posts: 4,686
    Looking at the headline I thought someone had figured out how to add soap to the hot water pipes, thereby dispensing "sudsy hot water"!
    ScottG Administrator Posts: 5,693
    Hmmm. That could eliminate the need to wrangle a bar of soap in the teeny tiny shower!
    Sadly, this might mean you would have to rinse with non-sudsy cold water.  Back to the drawing board!
    Oh yeah. Good point!  :-)
