Alde heat not working
My Alde is not heating the interior, I have hot water. The front display is showing 158F cabin temperature I think it's thermostat related.
    ScottG Posts: 5,688
    Gotta' agree with your assessment.
    The heat source for hot water and cabin heat is the same, so that is not the problem. However, if the Alde thinks the cabin in 158F it will not engage the circulator pump and none of that heat will make it into the cabin.
    Hopefully someone else can offer tips for trying to reset the thermostat.
  • I think there is a reset on the thermostat screen.
    You have to go toe the settings menu.
    Others have said that killing all power will reset the system.
    I'm sure others more knowledgeable will chime in.
    Tampa FL
  • RFraer
    RFraer Posts: 92
    I think it's fixed. I found on the forum where people had the same problem. Turns out under the display cover there is a thermal spring and a thermalcouple. If the components get to close it throws the thermostat off.
  • runaway30
    runaway30 Posts: 86
    RFraer, Can you give a little more detail how you fixed the problem for future reference please?
