Took our 2014 T@B Q out for it's maiden voyage this weekend.
Tried to use hot water with no luck. Read many "tips" on the controls.
Our dealer went over controls in detail with us as well.  We never had
the water even get luke warm let alone hot. Looks like I will be contacting
dealer.
                Sara & Mike/2020 AVIA #0066/Denver, CO
2014 Toyota Sequoia
0 ·
2014 Toyota Sequoia
Minnesota
Practicing to be a wanderer
2020 T@B 320 CSS Boondock Lite
2014 T@B 320 CSS M@xx
2020 Jeep Wrangler Unlimited 8 speed automatic
2020 Jeep Grand Cherokee Limited V8
2018 Jeep Wrangler Unlimited Rubicon 6 speed manual
J.D. & Sue
OK Guys.... I took the T@B out this weekend and NO HOT WATER!!! I am soooo frustrated with this. Instead of going camping last weekend I took the T@B to the dealer like I stated I was going to do. The guy there looked it over said it worked just find and this is typically "user error". I went over exactly what I had done (which is exactly what he did) and did not get hot water. I was very careful to do exactly what I was instructed. NO HOT WATER. NOTHING. FYI my controls are prehistoric. It does not look anything like the one in this stream.
Also, that Velcro screen door has got to go.. Anyone know where I can get the "newer" sliding screen door?
2014 Toyota Sequoia
Got a pic of your "ancient" controls? Is it not like our three sliders and a dial controller?
You did have water in general, just not hot water?
Are you able to get heat out of the Alde?
Hooked to shore power or on propane?
Minnesota
2014 Toyota Sequoia
J.D. & Sue
There is a diagram in the PowerPoint file in this thread. Mine was somewhat reversed, but it should give you the general idea.
Minnesota
It may be that you just haven't run the water long enough to purge all the air from the system.
You'll need to open the hot tap until the air stops coming out. Then give the Alde some time to heat the water (15-30 minutes) and you should be able to get hot water.
Keep us posted!
2014 Toyota Sequoia
Tom & Pam in MD
2014 T@B S M@XX 2014 Subaru Outback
Obviously this isn't a wide-spread problem as we don't hear too often a need to get at the Alde fuses. Probably isn't actually an Alde problem either (to my way of thinking).
I'm not much of an electrical trouble shooter so hopefully someone else will jump in with further thought.
I'm not sure, but I think that may have been the cause.
I'm careful now to turn off all the switches on the Alde control panel before plugging in....
Let us know if you find that to be the case, too.
2014 Toyota Sequoia
2014 Toyota Sequoia
When you had those symptoms, did it ever work for you, ie was it intermittent?
Mine has randomly blown one of those fuses a couple of times, but otherwise it's been great, and I just wonder if I should bother with contacting Alde about it.
Be brave. Take risks. Nothing can substitute experience.-Paulo Coelho
