City Water Fills Fresh Tank
JeffroNC
Member Posts: 366
On my 2019 TAB400 There must be a check valve between the city water plumbing and the fresh water tank. Mine is leaking slowly. When I am connected to city water, my fresh tank level goes up. Any ideas or a photo?
Jeff & Amy
Jeff & Amy
Now in Manistee, MI
This thread has a discussion about a "sticky" check valve.That thread has this thread inside it, which breaks down the entire pump! And gives some help for a stuck valve.
Towed by 2014 Touareg TDi -
And, one more about the check valve.
I believe the water pump itself prevents city water from flowing into the fresh tank--either by an internal check valve, or just by the nature of the pump's mechanics.
Per pthomas745's second link above, it looks like it might be repairable.2015 T@B Max S (320)
Mine was doing the same thing on a 320. It was missing the strainer and dirt got into the pump. I pulled the pump out and disassembled it. Was just a few screws. Pulled bits of plastic? out of the diaphragm. Put it back together and no more backflow. And I bought a strainer assembly2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL -
Thanks folks. Last night I discovered that it is leaking in both directions. The pump runs periodically when city water is disconnected. I’ll take it apart tomorrow.2019 T@B 400 BDL 2017 F150 3.5L Ecoboost
Jeff & AmyNow in Manistee, MI
- 916 Introductions
- 72 Teardrop Groups & Links
