I’ve got a crazy idea! Just last month, after 3-4 years of wishing and dreaming, we were finally able to buy the T@B we were hoping to have one day. It’s exactly what we wanted: a 2019 320 cs-s Boondock Lite. We love it! We weren’t really going to be that picky about colors, but then we found a deal on a TV that we couldn’t pass up: a 2017 Toyota Tacoma TRD 4x4 Off Road...and it’s red! Our new trailer is silver with blue accents. Now, don’t get me wrong, we can be very happy with a red pu and trailer with blue accents. But I was just thinking...I wonder if there’s someone out there that has a T@B like ours, only with red accents, and they would prefer blue...and they live near enough central Oregon that we could negotiate a trade — of just the fiberglass accents, not the trailers. If you’re the person I’m talking about, I’d love to hear from you.
Removed the pieces, scrubbed them, sanded lightly, washed again, then used spray paint made for plastic.
Came out really nice.
Other alternative is to remove a piece and take it to a body shop to see if they can paint plastic.
If they can, remove all of them and take them in.
Tampa FL
Central Oregon’s High Desert
https://tab-rv.vanillacommunity.com/discussion/comment/136631#Comment_136631
Click on the link that @pjabbott posted about his painting project.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePo4; Solar: Renogy 100Ah Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Tampa FL
Our wheel well trim might be different too. The screws are about 10 & ¼" apart.
The screws along the bottom of the side trim are 8 & 5/8" apart.
(We’d deal with our red ABS tub separately.)
Easier in the sense that I would venture to guess you won't find someone to trade, straight up in any reasonable period of time. That is compounded by the limiting factor of a specific color...
Cheaper relative to the original suggestion that I thought of in wrapping the taco. Removing the plastic bits is easier enough, plus the cost of a couple of rattle cans and some prep time...
Ya, great if you can find someone to trade. Keep in mind they may have personal attachment(s) to the inside that they have customized to their personal taste...
@4ncar the discussion was to just swap the trim bits, not the entire trailer.
So, if I have a 2019 Boondock Lite, then, according to what you said, I DON’T have Boondock style fender flairs, and mine are then the same as the 2018 non-Boondock fender flairs. How can I know for sure, since I can’t tell the differences in the pictures?
I don’t want try to remove the T@B insignia on the hatchback. I would be satisfied with the fender flairs, the window trim, and the handle escutcheons. Let’s see if we can discover if the fender flairs are identical sizes, or not.
That said, you can still use the standard fender flair on a Boondock axles, all the earlier Outback’s and 2019 Boondock used the standard flair. It just takes jacking the trailer higher and slipping the tire out bottom first when changing trie/wheel.
2008 Toyota Sequoia 5.7 L
Here’s a better angle.
So we both have the origin standard wheel fender flair, which is thicker at top center where it flattens out compared to the width at the sides.
So your blue flairs are the same as ckjs’ red flairs, which look different because his wheels are further up as he does not have a Boondock axle, and the TaB is riding lower.
I also measured the distance between the fender screws: the bottommost ones are 30 & 7/8” apart from each other; the middle ones are 18 & 7/8.
