TAB 320 Fresh Water Gauge
I have filled my tank, let it gurgle to get air out and settle, run pump to charge the system and topped off but the fresh water gauge is just barely getting to the FULL indicator. It certainly seems full but the gauge seems off a bit. Its didnt do that last season.
Any thoughts?
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 10,014
    If you opened the hot tap when you ran the pump you would reduce the fresh water tank by about 2.5 gallons to fill the Alde water tank - that could account for less than a full tank.  Also, are you level?  You can try to raise the tongue and add more water, too.  Also, the tank monitor seems to work with a range of volume, so it is not terribly accurate.
    By raising the front of the trailer as far as possible I was able to add almost 4 gallons.
    1. Hash  T@B Fun
