Ned help with electrical on new TV
LynMLynM Member Posts: 1
We’re looking for a 7-way wiring solution for a 2021 Odyssey EX-L. The fuse locations 10, 11 and 12 on the driver's side cargo area bulkhead have metal clips to accept a fuse. Someone has suggested a Bluetooth brake controller. Any ideas would be appreciated.Thanks.
  • MarcelineMarceline Member Posts: 1,734
    If you’re planning to install the 7pin connector yourself, I’ve had good luck using the eTrailer.com website to get the appropriate parts for my vehicle.
    @LynM - Not sure about the Bluetooth brake controller, but we had a Prodigy RF brake controller installed on our TaB A frame.  Although we did not need to have a brake wire installed as part of the 7 pin, we had them install it anyway, just in case we sell the van it would have a full 7 pin.  Don’t forget to ask for a charge wire and make it 10 gauge to offer less drop in voltage and better charging of the TaB battery.
  • CharlieRNCharlieRN Member Posts: 438
    We also have the Prodigy RF controller, chosen so as to not have to run a line to the brake switch (the batter and relevant fuse panel on our TV is in the rear of the car). I had previously installed a 4-pole connector, so installing a 7-pole was quite a bit easier, essentially requiring only a connection to the battery (via a circuit breaker) and a ground. The suggestion by @Sharon_is_SAM for 10 AWG for the battery connection is a good one. As others have suggested, etrailer is a great source of information as well as parts - there are a ton of installation videos and you should be able to find one appropriate for your situation.
