In preparation for our 2021 400 BD's arrival I'm doing some research on helper springs. I know Mandy Lea uses Hellwig helper springs on their Tacoma and I'm also considering Sumo Springs. Does anybody on here have any experience with either? Sumo Springs look easy to install but I don't know if I like the idea of using the frame as a supporting point load while towing. The Hellwig leaf springs look a little harder to install but seem to make sense because you're utilizing the entire leaf pack to carry the load. Thoughts?
2021 400 BD
2020 Tacoma TRD Off-Road
0 ·
I had a thenJeep Dealer’s shop replace my rear springs and shocks, with progressive tension springs designed for my truck for towing heavier loads. Going with a purpose designed solution for towing is always the better option, and not a bandaid (helper spring) approach.
The Hellwig springs, I believe, are progressive tension springs. They're supposed to ride fairly normal without a load but stiffen the leaf pack as weight is applied. Sumo springs are just essentially giant bump stops.
Odessa, Fl.
2020 Toyota Tacoma TRD 4x4
SW Colorado
But to answer, it includes a full tank of fuel.
Odessa, Fl.
From the research I have done, it appears that the reason there is no clear answer, and so much confusion in getting a straight answer, is that the various sources (including RV owners) use varying or incorrect terms. What needs to be determined is the “payload capacity.”
The formula for determining payload capacity is: Gross Vehicle Weight Rating (GVWR) - Curb Weight = Payload Capacity.
I have concluded that part of the confusion is that a full tank of gas is included in the “curb weight” (i.e., empty weight) of the tow vehicle. Thus, it is not included as part of the “payload capacity.” A simple way of viewing “curb weight” is to think of it as the weight of a vehicle when it leaves the factory, including a full tank of gas and topped-off fluids. Anything beyond that, such as add-ons/accessories, the driver, passengers and cargo (including trailer tongue weight), will be counted toward the total available payload.
GVWR - This is the maximum amount of weight the vehicle chassis can safely carry/support. Put another way, it is the maximum total safe weight of your tow vehicle, including the curb weight, the weight of the driver, passengers, fuel, any accessories added to the stock vehicle, and cargo.
CURB WEIGHT - This is how much the tow vehicle weighs when empty, BUT includes a full tank of gas and topped-off fluids. If it is not included on the manufacturer’s label on your tow vehicle door post or some other source, the best way to determine the curb weight is to weigh the vehicle while empty, with a full tank of gas.
It is important to remember that after determining your tow vehicle’s payload capacity, you need to deduct the “tongue weight” of your trailer (i.e., 10-15% of the combined trailer weight and additional cargo it is carrying) to determine how much payload you have remaining to add to your tow vehicle.
If I am wrong in my conclusions, I am all ears and open to any contrary input.
