Hello.. I have searched the forum and the Alde site but am not able to come up with this answer.
Does anyone know the draw (KWh ?) of the Alde heater when connected to 110 shorepower?
I have a new 2021 T@B 320 Boondock.
Outside temp in the 20-45 F range. Heating the interior to the mid 50’s. Alde set to “1” on the electric power. Fridge is off.
The reason I ask... I am at a cabin off the grid and for some reason am seeing a significant daily energy draw on the cabin system of several KWhs The only thing “different” than our normal stay here is the T@B ... but I can’t imagine that the Alde would pull that much energy.
The only other draw would be the converter .. but that is simply helping to keep our batteries topped off. But the T@B’s solar helps with that during the day.
Thanks for your help.
The manuals don't state it very clearly, but the Alde FAQ does. They go with about 0.2 to 0.6 of an amp (which I assume means when it is running), with a few seconds at "1.9A" as it starts up.
How much electrical power does the heating system use?
There are two mechanisms in the Alde Compact boilers that draw >0.1 A current from the vehicle 12-volt battery. The exhaust fan venting waste gases (≈0.4 A), and the heating fluid being pumped around the circuit (≈0.2 A). So normal draw from the vehicle battery is between ≈0.2–0.6 A, including the control panel. Max draw is 1.9 A for approximately three seconds at system start-up.Max draw from 120 V mains is ≈4.5 A on 1 (1 kW) or ≈9 A on 2 (2,1 kW)
Of course they are not on continuously, but even if they run ten minutes out of every hour that is still four hours of operation per day at a cost of 7.6 KWh.
How much they actually run will depend on a lot of variables. If you really wanted to sleuth it out you could do a heat loss calculation based on temperature differential, insulation, air exchange, and boiler output. T@Bs really aren't designed to hold heat in very well.
In addition, IIRC, the circulator pump has the capability to automatically switch to 120V when available-- though I doubt that will contribute much to the power usage relative to the heating elements.
In general, any time you turn on an electric heating element, expect your power meter to spin happily.
The Alde control panel has a day and night setting feature that lets you automate the heating temps by time of day and night.
