Hi, newb to EVERYTHING about campers and towing as well as this forum!
I'm looking at towing a Dutchman. To tow it I'm aiming to buy a used vehicle with a V6 engine.
Should I focus on vehicles with factory installed hitches? What about aftermarket hitches? What's your experience been?
Thanks!
If your "V6" is a truck chassis with a solid frame to bolt to, probably just about any quality hitch will likely be fine. If you are attaching to a unibody vehicle--more like a typical car--you might want to research more carefully.
There's a old post here about somebody's aftermarket hitch ripping right off their unibody chassis, complete with pretty scary photos. IIRC it had to do with the geometry of the hitch and the relative weakness of the attachment points. While this was a very rare event, but that is not much solace when you are that one-in-a-million.
Admittedly, I'm not real knowledgeable about this. However, if I had a choice, I agree with @MikeDawn265 that the safest bet is probably a hitch designed and installed by the car's manufacturer.
Don't shoot the messenger. Like I said, I don't have a lot of personal experience in this realm. I'm just making reference to an incident reported by another forum member regarding unibody structural failure from an aftermarket hitch that had been installed by a trustworthy mechanic. Maybe there is more to the story.
I think a lot of it is going to depend on the hitch set-up. The Escape itself has the power to tow 3500, but the caveat I missed several years ago was that that is with a factory installed tow package. I finally found, more recently, a tow guide from Ford that has that information. It was my mistake for missing this when I first went about setting up to tow.
The aftermarket hitch I had is by Valley (which in turn is made by Thule). It was a class III hitch rated at 400/4000. It was installed correctly, and I even found a short installation video on eTrailer. This is installation on an '09 Escape, but the frame has not changed.
It seems that the Valley hitch is a bit different then other hitches made by other manufacturers, and that could have also contributed to the failure. Below is what the Valley hitch looks like:
(Mod note: added quotes to Cyclonic's response to Geo from 2017 discussion.)
