Bathroom sink upgrade - T@B 400
2»
  • TresK3TresK3 Member Posts: 85
    Nicely done!
    Question: was there a reason to put the faucet on the right?  Or was that the only option for the hole?  It looks like you'd have slightly better clearance to get to the pocket shelf if you put it on the left.
    2019 Tab 400 Boondock Lite
    2017 Dodge Durango AWD with Tow Package IV
    A can of Skyline Chili in the pantry
  • 3DogHouse3DogHouse Member Posts: 3
    edited April 2021
    @Kevin@7 or anyone else on this thread?  How do I remove the little white tabs and then whatever is behind to access under the bathroom sink?  I need to shut the water off to the toilet or whole bathroom.  Any help greatly appreciated.
    2020 T@B 400 Boondock Lite
    edited April 2021
    The little white or beige tabs should just pry up and off.  The shower water lines run under the closet (or 3-way fridge if you have that option) on the right just under the closet floor and go up into the panel behind the right back corner where the glycol reservoir is located.  The sink and toilet line is down near the floor.
    There are two shut off valves (one blue/cold one red/hot) on the pipes along the back.  These turn off the outside shower, and may turn off the sink and toilet also.  Otherwise, you need to find the lines in the closet, and cut them and add a shutoff (called a stop) valve.
