I have no direct experience however web searches note . . .
With Atwood out of business there aren't any exact replacements for hydraulic couplers generally available. Most web-articles suggest: 1] searching local boat trailer shops to see if they have old (dusty) stock. 2] doing minor modifications to other brand/model parts to fit your Atwood. 3] replacing full Actuator with an available today brand, replacement cost should be <$200 or so + installation DIY installation is possible (option I would select)
Hi. Finally its done. Demco # 8605001 works. Installation was't easy, you need to trim the top plate and replace the straight connector on 90 degrees (master cylinder).
Adventures: 52 Nights: 329 Towing Miles 41,900+
Calgary, AB
2014 T@B
2013 Toyota Venza
