My simple solution to block Jensen cube light at night
ChopinChopin Member Posts: 47
edited April 2021 in Modifications & Upgrades
  • krsmeskrsmes Member Posts: 88
    If you tap the power button (vs holding it down) it will turn the leds/display off.
    Ironically you can’t do this when the unit itself IS off.
    My next mod when I get back from this trip is to install an external power switch to be able to shut it completely off, zero power, when boondocking.
  • ChopinChopin Member Posts: 47
    Thank you!!! I had tried to figure this out :)
  • ChrisFixChrisFix Member Posts: 741
    edited April 2021
    @Chopin
    You can turn the display completely off in settings. Set the Dimming to the lowest setting, which is completely off, then simply press the power button and the screen will dim, in this case to black. Press the power button again, and it comes back on.
    No foil needed!
