 jimbo17
                    Member Posts: 4
jimbo17
                    Member Posts: 4
            Hi,
I have a 2008 T@B CS with stock tires and steel rims. 195/60/15 I am looking to replace with new 2016 alloy rims and conventional tires.
Has anyone done this?...if so, what is the appropriate new tire size. eg. 205/75/14 looks comparable? The bolt pattern also looks a little different than a regular trailer 5 on 4.5 bolt pattern? Did you use a conventional Auto or RV alloy rims?
Thanks for the help and advice,
Jim
The tire size for the Alloy Rims is 205/55/R16
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
5 Spoke Alloy (marked JWL-Japan Light Wheel Alloy)
16x7"
Bolt Circle: 5x112mm
Offset: 37mm, Positive (measured at 38.1mm)
Lug Bolt Size: M12x1.5, 24mm thread length, (54mm overall) Conical Seat
w/ 17mm Socket size
Mounted to AL-KO Euro Axle w/ Brake Drum/System #1637 (160mmx37mm)
Original Tire Size 205/55 R16, weight rating 91T
Discount Tire was able to source replacement wheels for under $100/ea
The only other match for this size that I could source was:
1997 Mercedes CLK 430 205/55/R16 7x16 ET37 E-208335
MOUSE-KE-T@B
Harvest, AL
I would keep the stock AL-KO axle, as this is a great setup with surge brakes, which do not require an electrical brake controller in the tow vehicle. Adding the shocks should get you a small lift, you already have 16-inch wheels, while the new Boondock axle/wheel is a 15-inch wheel/tire. uses, You may be able to get a slightly larger diameter (outside diameter) AT wheel to fit your current rim, which along with the shock kit, would raise your ground clearance by an inch or more.
