Refrigerator Door TAB 400
Jimbrookover
Member Posts: 2
Hi - How do you open the frig door wide enough to remove and change the divider height?
Thanks!
Thanks!
Which fridge do you have, and what year TaB400?
If tab 400 compressor (isotherm cruise 65) frig, you have to pull it out of the cabinet a bit in order to remove the door, then you can adjust the shelf. It was easy, took me about 30 mins. I'd link a vid or manual but we are in a campground with slow internet. There are 4 screws inside that have to be removed. Then pull the frig out a bit, remove bottom or top hinge and the door should come off.2021 T@B 400 BD, 2021 Lexus GX 460, Kansas City MO0
Well that is a pain rhyno, best make sure you get the shelf where you want it.
- 417 Service/Maintenance & Recall Notices
