Refrigerator Door TAB 400
Hi - How do you open the frig door wide enough to remove and change the divider height?
Thanks!
    Denny16 Member Posts: 5,430
    Which fridge do you have, and what year TaB400?
  • rhyno
    rhyno Member Posts: 393
    edited May 2021
    If tab 400 compressor (isotherm cruise 65) frig, you have to pull it out of the cabinet a bit in order to remove the door, then you can adjust the shelf. It was easy, took me about 30 mins. I'd link a vid or manual but we are in a campground with slow internet. There are 4 screws inside that have to be removed. Then pull the frig out a bit, remove bottom or top hinge and the door should come off.
    Well that is a pain rhyno,  best make sure you get the shelf where you want it.
