T@b Task Day
jkjenn
jkjenn Member Posts: 6,424
I took today off to get a few things around the house and T@b done. Too bad it feels like a tropical rain forest today.
I finally added a battery cut off switch and mounted my fishing rod-flag pole holder (thanks, @dalehelman !) My flagpole arrived but I realized I also need a new flag. Hoping it dries off and I can get to my caulking work.
  • judymac
    judymac Member Posts: 403
    Good job!
  • Nomad
    Nomad Member Posts: 7,209
    Post a pic of the flagpole set up - What flag ya flyin?
  • jkjenn
    I have to wait for the weather to clear; it started to rain. :) I will be flying the stars and stripes of the good old USA!
  • jkjenn
    I could not fully extend it due to overhead wires and tree branches. I used pipe insulation foam to snug the flagpole in the rod holder. The last picture is a close up of my wireless antenna (Ubiquiti Nanostation M2. I have one more piece to the puzzle arriving tomorrow and a new flag on Wednesday. I think I could probably rig a plate for the cell phone booster but not sure I will do that right away. The WiFi antenna is mounted to the pole with a mounting plate.
  • Cyclonic
    Cyclonic Member Posts: 1,232
    The setup looks good.
    Sterling, VA
  • Nomad
    So, did it all go together as easily as expected?
  • IACamper
    IACamper Member Posts: 109
    Jenn, did you fasten your cutoff switch with adhesive?
    Kristi Des Moines, IA 2008 T@B L
  • jkjenn
    Yes, I used a 2 5/8" hole saw to cut the hole in the battery box cover moved the wire from the battery to the switch, added a tray cable from the switch to the battery, tested, and that was it.
    Yeah, I used silicone, but might next to use gorilla glue, too. There is not a lot of surface area o. That switch to add the adhesive.
  • IACamper
    Thanks. I used screws, but I'm nervous about the tips of them coming into contact with something electrical....
  • ChanW
    ChanW Member Posts: 3,165
    edited July 2015
    Jenn, Gorilla Glue is great, but it's a little 'brittle' for flexible substrates. You might want to use a kind of construction adhesive for plastics. Dunno what tho... B-) I have this polybutylene stuff that sticks like mad, and stays rubbery/flexible, but you gotta buy a whole caulk-size tube.
  • Rad
    Rad Member Posts: 516
    Adhesive silicone chalk would work great for that.  Keep in mind that you will have to cut it off if you ever want it off.
  • jkjenn
    I got a little sloppy with my wrench when I was tightening down the nut on the battery. It woke me up, for sure!
  • Rad
    That's funny.  We have all done it.
  • Verna
    Verna Member Posts: 6,876
    Been there, done that...will probably do it again.  Be careful.
  • jkjenn
    Yeah, I wish I could say it was the first time.
  • kybob
    kybob Member Posts: 232
    Jenn, what do you mean by a "tray cable?" Thanks!
    2018 Outback S, Silver/Black - 2015 Silver Honda Pilot 4WD - Florence, KY
  • jkjenn
    A heavy duty battery cable, like this one. I should add that I ran the switch to the negative side of the battery.
