I'm 99% sure the black water flush check valve is piped backwards.. It looks like I need to remove the complete sink housing to investigate.  I'm at a loss on how to remove the sink basin, which will allow me access to the two remaining screws directly behind the sink basin.  After I'm able to remove the white plastic housing I hope I can remove the plywood to gain access to the check valve.
Thank you for any help,
Sweet Haven
(Title edited for search purposes.  Moderator)
                0 ·
How did you know to look for this - what's the failure mode look like? Are you unable to get water to flow to the flush sprayer?
Thanks!
