Dual propane mod (2021 Tab 400) - options for longer pigtail?
We received our second aluminum propane bracket and had it welded down today (see photo).  However, the existing pigtail is too far to reach the second tank so I'm wondering about options.  The easiest one is do nothing and simply swap the tanks when the one on the left runs out, but the perfectionist in me is thinking of being able to just unscrew (or even flip a switch) to transfer to the other tank.  So I am wondering:
- anyone replace their pigtail with a longer one?  If so, does the current one easily screw off and a replacement standard Camco one would just thread on with some yellow gas tape and I'm good to go?
- anyone find any Y-adapters, extensions, and or switches (I've seen these on off-the-lot RV setups but nothing aftermarket) - would be great to simply screw an adapter (Y or T) onto the existing pigtail.  I've seen *some* extension cords, but they typically are like 20 feet long.  All I need is an extra 1-2 feet to reach the second tank!
ps. the bolt/nut that came with this item were way too short, versus the nice long bolt + wingnut that came with the original camper.  Shame nuCamp lol - I'll just pick something up from the hardware store at some point..
  • TomCanada
    TomCanada Member Posts: 294
    That would probably work but might be a bit overkill - it would require replacing the entire regulator - I'm hoping for something as simple as a 1-2 foot extension hose, or someone to help confirm I can easily replace the existing 1 foot pigtail with a 2-3 foot one using nothing more than a wrench without worrying about leaks, stripping threads, or other craziness.
  • Homeyfogle
    Homeyfogle Member Posts: 4
    Yes you can. I just recently did this. You can go to a propane dealer or get it on Amazon (Propane pigtail hose connector 12-60"). I took my regulator to the propane dealer to ensure it connected before I purchased. Just remember to get/use some gas line thread sealant to attach back into your regulator. The sizing is confusing but its a 1/4' female connector to your tank and a 3/8" male connect to the regulator (don't quote me).
    Jim & Mel
    T@B 320 S 2018 / 4Runner Nightshade 2019
    Parker, Colorado
    @TomCanada, Make sure you get the right end on your new pigtail. There are male "flare" ends and male NPT ends, and they are not interchangeable. Mine has the flare ends.
    Also, I do not believe you should use sealant or tape on these types of fittings.
    Gas is not something to mess around with. There are different fittings and different standards for attaching them. Don't take my word for it--do your homework and make sure you know what you are doing before making any changes to your propane supply lines.
