When I connected to city water to dewinterize my 2021 T400 I got a large leak from somewhere inside the Alde box! The leak stops when I put the two yellow relief valves in the upright position directing the water outside through the drains. If the heat exchanger coil inside the Alde unit is the problem I’m sure the entire unit will have be removed or replaced which will take weeks here in Canada, our dealer isn’t taking service bookings until July! Does any one know if you can bypass the water heating elements of the Alde system? Then we could at least use the unit while we wait. The flood also knocked out the 12V system, the main breaker in the passenger-side cargo space won’t reset. A dark day in Saskatchewan.
