3 way Norcold fridge in 2017 Tab 320S
lkc001
Member Posts: 881
Can someone with this same fridge tell me if the light is supposed to glow green when plugged into electric? It glows green when on propane but I'm not seeing the green light on electric. Thank you
2018 Tab 400
No the green light indicates there is an active flame when operating on propane.
- Hash T@B Fun
@Dalehelman and @lkc001 the 2017 320S the green light indicates that you are connected to shore power. Dale, my green light looks like an electric plug.
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red0 -
I think they changed the 3-way fridge model sometime around 2017, but I don't know the exact timing. Mine is like Dale's.
So, I guess the answer depends on which model fridge we are talking about.2015 T@B Max S (320)
It appears that mine only has the green light glowing when on propane & flame is on— it works on electric fine— but no light to indicate that it is on when plugged in to electricity—the only way to know if it is on is to wait a few hours to see if it is cooling down— have never tried it on battery & don’t plan on it2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab0 -
@Homebodyatheart. We must not have the same fridge— I don’t have an electric plug that glows green on mine2018 Tab 400
@lkc001, we have an early 2017, build date April, 2016. We have the same fridge as @Dalehelman and @ScottG. I think the switch to the newer model Norcold began with 2017 t@bs built in July, 2016. I think @Homebodyatheart has the newer Norcold fridge. Hers is black and we have the light gray colored one. This is one of the mid model year changes nüCamp has been known to make.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus.0 -
Late 2017 ModelsNorcold 3-way model N180.3 with side vent and fan. No freezer.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
@Sharon_is_SAM. Yes —That is my model— it is also gray— thank you for the model # in case I ever need it.2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab2 -
Thank you everyone for the info— this group is the only way I have learned so much about my trailer— invaluable!2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab1 -
Ikc001- known issue with the green indicator bulb burning out on the 180.3 series three way. I replaced mine within 1 year with an LED bulb. I will search for the post and repost once found.‘18 Tab 320S- mfg’d 4/17, acquired 9/17
Huntington LI0 -
Huntington LI1
