Tampakayaker please resize your photos and repost.
2016 320 S
Packed up yesterday after 5 days camping hooked up to city water (with a regulator).  Used water mainly for flushing toilet.  Disconnected hose from water pedestal after turning off the valve, then disconnected at the camper.  Went to the restroom and when I came back I had a slow steady drip coming from the underneath edge where the floor touches the wall, and also eventually by the black tank 90 degree fitting to the clean out tube.  Checked the black tank and it was about 4 inches below the top, no water in the grey or fresh water tank. Did a quick check by the pump and didn’t feel or hear anything.  I opened the faucet and had water come out for about 30 seconds.  Hour drive home, parked in driveway and no drips.  Before I get started blindly tearing apart things does anyone have an idea of what would cause a leak with no water connected or where to start looking.  I haven’t hooked water back up yet.
Stick your phone down by the pump and take a video, make sure the flash is on, to see if maybe the a connection is leaking down there. It was in mine but still have not figured out what.
Picture was resized
Tampa FL
Tampa FL
https://tab-rv.vanillacommunity.com/discussion/8617/fresh-water-leak-fixed-again/p3
That topic has photos of the connection as viewed from inside behind the toilet where you cannot see - do it by feel, reaching below the fresh water lines.
You may want to also rule out other leaks from sink & shower, but I'd bet it's the city water pipe, which is under pressure when using either water source - city or fresh tank/pump.
Tampa FL
Odessa, Fl.
