How long to charge battery with solar?
    edited May 2021
    Loaded question, max solar charge rate will be around 8 amps (100/12=8.33). So it depends on the state of charge in the battery when you begin.
    Brad
    2020 400 BDL aka "Boonie"
    Concord, NC
  • boiseitesboiseites Member Posts: 23
    Well, it is a brand new Renogy battery.  So, minimal charge???
    It will still depend on the depth of discharge. The age of the battery (older has higher internal resistance) will take longer to charge or may not fully charge.
    Example, if in 24 hours you use 24 Amp Hours it will take at least 3 hours to fully recharge in full sun. You can replace the energy used (measured in Amp Hours) at the rate of approximately 8 per hour.
    The only way to reduce the charge time is being able to charge at a higher rate or use less energy.
    Brad
    Concord, NC
  • pthomas745pthomas745 Administrator, Moderator Posts: 4,281
    What are you using to monitor your battery?  What readings are you getting?  Are you measuring a "rested battery?"
    Be aware that it can take a new battery multiple cycles before it assumes it’s full capacity.  Check out your battery specs.
