Bathroom Sink
wlkinard
Member Posts: 1
How do you reconnect the bathroom sink drain that has fallen into the space between the sink basin and the bottom shell?
Bill K.
Bill K.
What model and year trailer?
I have the same problem as Bill K. The drain has disconnected and fallen into the abyss in the sink. Can anyone help with this? 2018 Tab 400
@Jody_George The same thing had happened to me. I gave up trying to fish it out. Brought it to uCamp 2019 and got a new-style square sink under warranty, which was a surprise. It might be an expensive fix for you. I'm sure there's a way, but even nuCamp chose to just replace it.Jean & Arnie Nevada
2019 T@B 400 BL
2021 Toyota Sequoia 4WD -
You are going to need to remove the entire sink enclosure unit,to get to the drain under the base of the sink unit. Replacing with the newer 2020/2021 sink unit is another option, or just remove the sink unit and replace with a small standard RV sink, as another TaB400 owner did, or just remove it entirely and put a waterproof plastic panel over the wall to seal the area off. The last option gives you a larger shower area.
Or replace with shelves...
Rich2019 T@b 400
2025 Toyota Highlander 2.4L TurboBellingham WA
- 920 Introductions
- 74 Teardrop Groups & Links
