@Jody_George The same thing had happened to me. I gave up trying to fish it out. Brought it to uCamp 2019 and got a new-style square sink under warranty, which was a surprise. It might be an expensive fix for you. I'm sure there's a way, but even nuCamp chose to just replace it.
Jean & Arnie Nevada 2019 T@B 400 BL 2021 Toyota Sequoia 4WD
You are going to need to remove the entire sink enclosure unit,to get to the drain under the base of the sink unit. Replacing with the newer 2020/2021 sink unit is another option, or just remove the sink unit and replace with a small standard RV sink, as another TaB400 owner did, or just remove it entirely and put a waterproof plastic panel over the wall to seal the area off. The last option gives you a larger shower area. cheers
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
2019 T@B 400 BL
