Batteries not charging all of a sudden?
Hello All,
We just returned from our inaugural trip with our new TAB 400 2021 trailer, and suddenly, it seems that the battery wont charge?
We had solar for a few days and had the propane on after a full charge from home before our trip and everything went fine. In fact, we never lost battery once, it was full the whole time for us and we were boondocking!
After we returned, we had it in the driveway for 24 hours, plugged in the charge when we got home, not that we needed it ( the battery still read full from the drive and the sun), and it worked great. we were in it in the driveway and the lights and radio and pump and everything worked fine. .....but, when you unplug it now, the battery is empty and there is nothing there. First, thats weird, because we were full when we got home and i turned off the propane and the minifridge right away, and it seems that there is a disconnect between the charge going in and the battery receiving it?
We have had the battery on the "on" position
I have checked the fuses and breakers and they are fine, but they should be because when i plug it in it all works,  its when i unplug it, there is no battery on anything whatsoever in terms of a charge.
Batteries damaged somehow?
Thanks in advance for any thoughts or recommendations.
Best,
Jeremy
