Alde Leaving Water In Tank
manyman297
Member Posts: 1,436
How long can you leave water in your freshwater tank? Also, if the Alde isn't being used for hot water or heat between uses, do you just drain your hot water low-level drain?
2021 400 BD
2020 Tacoma TRD Off-Road
The operator's manual states to drain the fresh water tank after each trip and to leave the yellow drain valve open when not in use. I've also started using a hose filter when on city water in order to minimize corrosion.2016 Outback 320
Which valve is yellow?Tabaz said:The operator's manual states to drain the fresh water tank after each trip and to leave the yellow drain valve open when not in use. I've also started using a hose filter when on city water in order to minimize corrosion.2021 400 BD
2020 Tacoma TRD Off-Road0 -
It's the valve that feeds cold water into the Alde at the bottom front. The first photo shows the valve open to drain, the second is closed to fill the tank.2016 Outback 320
2024 Ford F150 Supercrew short bed.1 -
Ok, got it. Thanks!2021 400 BD
@manyman297 - besides draining the Alde water tank, if you dry camped and used the water pump, you should also drain the fresh water tank after a trip.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Wow. I don't think I've ever done this. Of course, we camp sp regularly, the water doesn't stay in our tank for very long.2014 T@b S Max AKA T@dpole0
- 964 Air Conditioning & Refrigeration
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 920 Tips & Tricks
