Alde Leaving Water In Tank
How long can you leave water in your freshwater tank? Also, if the Alde isn't being used for hot water or heat between uses, do you just drain your hot water low-level drain?
2021 400 BD
2020 Tacoma TRD Off-Road
  • Tabaz
    Tabaz Member Posts: 2,420
    The operator's manual states to drain the fresh water tank after each trip and to leave the yellow drain valve open when not in use.  I've also started using a hose filter when on city water in order to minimize corrosion.
  • manyman297
    manyman297 Member Posts: 1,434
    Which valve is yellow?
    2021 400 BD
  • Tabaz
    It's the valve that feeds cold water into the Alde at the bottom front.  The first photo shows the valve open to drain, the second is closed to fill the tank.
  • manyman297
    Ok, got it. Thanks!
    2021 400 BD
    edited June 2021
    @manyman297 - besides draining the Alde water tank, if you dry camped and used the water pump, you should also drain the fresh water tank after a trip.
  • ChrisK
    ChrisK Member Posts: 280
    Wow. I don't think I've ever done this. Of course, we camp sp regularly, the water doesn't stay in our tank for very long.
    2014 T@b S Max AKA T@dpole
