Jenn, thank you so much for this helpful contribution. You and Mike (and others) have demystified so many aspects of camping with our T@bs. Especially for us newbies with the urge to spread our wings but not necessarily the know how. Appreciate. DDjkjenn said:We got on the topic of boondocking on another thread (http://www.tab-rv.com/forum#/discussion/621/red-light-on-alde-control-panel) and thought it might be helpful to dedicate a thread to boondocking, for posterity. I will start off with a few things we know about boondocking.
- What works off grid:12v outlets and accessories (TV, stereo, ceiling fan, lights, Alde - with propane, Norcold- with propane, water pump)
- What does not work off grid: A/C, 110v outlets, Alde - electric, Norcold - electric
- When using propane for heat and Norcold, the propane should last approximately 4-5 days
- Battery power is required for using both he Norcold and Alde off grid. In general, if the charge is below 11.2, the Alde will not have enough strength to work. The results are similar for the Norcold.
- The 11 gal grey tank will overflow into the shower on an S model or the sink on other models when it is over capacity. A portable waste tank (Telford, Barker, etc..) can be used to extend the time you can continue to use a grey tank. Some models have a ring on the Handel that will slip over the ball on your TV hitch for transport to the campground dump station.
- The 6 gallon black tank will not allow the toilet waste to be released to the tank when it is full.
- To preserve battery life, reduce or eliminate use of ceiling fan, TV, stereo, lights and water pump.
- Proper solar charging will recharge your battery. Many users report 120 watts minimum for those who are off grid and want to continue to use electronics. Solar will not provide you with any 110v usage (a/c, outlets, etc.) In order to use 110v items, an invertor must be installed.
- A generator of the appropriate power will recharge your batteries or can be used as a shore power source for your T@b. In addition to traditional gas only generators, Yamaha has a generator that will run off of propane.
I've had no issues filling a tank that was bought at a trade-in. As a matter of fact, we did it recently. One of our tanks had reached it's expiration, so we traded it and checked the expiration on the new tank and have been having it filled ever since.ChanW said:Pxl, I've never gone with the propane tank trade-in system because, from what I understand, the trade-in bottles have a proprietary filler system and can only be refilled by the trade-in program. Once you have one, you have to keep trading it in.PXLated said:Propane Refills are not created equal...
I was in an area where the only way to get a refill was trade in your current tank for a full one (Walmart is that way). I've found these vary somewhat and aren't always a full 20lbs. When possible, I always go for a refill where they weigh the tank.
Is that what you've found?
It's good to know that it's sometimes difficult to find someone to refill a traditional bottle.
A good reason to have a spare, and refill it as soon as possible!
Thank you. 2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
